AO and Sky X guiding
Hi
I have set Sky X as AO guider in Voyager.
The equipment profile in Sky X does include the AO unit and it is activated.
When calibrating, after the mount moves and it’s time to calibrate the AO unit with the mirror moves, Voyager returns an error “AO not supported in Sky X”, any workaround to solve this?
Davide
Davide, when I developed the AO methods for TheSkyx wasn’t way for third parts applications to manage it.
So there are not workaround … I can look if SB developer have expanded and implemented the needed methods
Grazie Leo, then I will use Maxim DL for the AO and frame acquisition.
Davide
I will keep in touch you … when I will be more free to look inside TSX library.
