My array setup included a setting of one second for the Array Virtual Mount Data Send Interval and General Data Send Interval. However, when I toggled the APCC - 3D Scope view before I executed a critical slew with weights up so I could see the mount, the array indicated that the mount was disconnected and I was forced to shut everything down and reconnect.
I experimented and changed these to three seconds to see if I could toggling the APCC - 3D Scope View and not send an error to the array which would indicated that I was disconnected from the mount. It seems that these settings worked. I believe I can now toggle the 3D view in APCC and still stay connected to the array.
Are there any additional unforeseen adverse impacts to setting these parameters to 3 seconds? What are the typical settings and tolerances for these two parameters?
