I know this is not a support forum but wanted to ask this question to see if any users had come across this or a similar issue
I have written some vbs scripts to interface with telnet to turn on or off my internet power switch because it is not currently supported by Viking, the scripts works fine from the command line and turn the power on and off, so I was feeling pretty smug and thought I had done the hard work
However when I try to run them from Voyager as an external script using drag script they wont run because I get the error that the telnet executable cant be found even though the script points to the absolute path for the telnet executable (c:/windows/system32/telnet.exe)
there is something strange going on because even when I try to call and run the telnet executable as a programme from within dragscript when I open the path to the system32 file the telnet.exe file is not visible to load into voyager as an executable even though I know it is there and can find it just fine using windows explorer.
no matter what I do I cant locate the telnet.exe from within voyager I have tried running Voyager as administrator etc but nothing works I’m completely stumped
any one got any ideas?
nik
