Camera Timeout errors in sequence
I’ve probably got a hardware issue with my USB cables, which I am sorting through.
However, when the issue occurs, I get camera timeout issues. Within a sequence, I’ll get a warning? I think, but it doesn’t throw an error. So, within my dragscript, the error block I’ve got does not trigger.
Is there a way to get these timeout issues to trigger the error, so I can run the error block in dragscript?
Although I’d like to see an error option here for camera timeouts, at least for me, I think I have worked out the hardware issue - by going direct from laptop to camera (1 USB cable) instead of laptop to mount, mount to camera (2 cables, plus internal mount cabling). It’s not an ideal solution, but I can live with it.
