Can I do a Mosaic using Array Sequence?
I have never taken a mosaic - using Voyager or otherwise. Creating the panes is a breeze with Web Dashboard. I have a mosaic sequence set up for my main camera (Array 1). I know how to create an Array Sequence but cannot see how to link this to the mosaic I’ve just created.
What should I do?
Thank you
Mosaic sequence work for a single node like in base version
Array have not mosaic section, you ca use center of the tiles to create more than one array sequence and use Dragscript to do all.
Thank you Leo.
So create one Array sequence for each panel and run them sequentially as targets?
Yes, you can also use the DO IF … if you need some check
I will add mosaic for array …
You are the man Leo! :dark_sunglasses:
Bump! :grin: :wink: Bringing this one back to life…not a priority obviously but would be great. DragScript works well even if it can only cater for 1 panel per Sequence.
Sorry Roberto, but at now I have a todo list long like distance from me and you also is not easy to do a sequence for mosaic with an array. I will add it … have faith :sweat_smile:
That’s fine Leo; I understand :+1: It was a cheeky request.
