I
I want buy Voyager but i use ccd sbig st10.
Is possible use this ccd not only for shotting but for autoguiding too?
Nello Ruocco
Osservatorio Astronomico Nastro Verde di Sorrento MPC code C82
I
Nello Ruocco
Voyager doesn’t manage old SBIG camera directly.
You must use Maxim DL or TSX Camera add on, in this case the answer is yes.
Hi Luca. If I understand correctly, then I can command the st10 both with filming and with autoguiding using the dual sensor.
Can try again the software but with possibilty using dual sensor?
Thank you
Nello Ruocco
Sorry Leonardo…i called you Luca
You are free to try Nello
Thank you Leo
Nello Ruocco
