This must be basic but I am stuck. I have Voyager ADVANCED. But I do not understand how to get the custom horizon window to “work”. How do I enter data or create the curve/contour? Must you start with an import?
Yes, you have to import a file. They are a couple different formats supported. I just used a simple text file with azimuth and altitude pairs like this:
0 22
31 22
40 42
133 63
154 53
178 57
229 14
276 18
310 21
332 22
That you “had to” import wasn’t made clear to me, so thank you. Often you see horizon features with a graphic input mechanism. It is probably unnecessary but in searching for that I was stuck.
Thanks Leo
H
Voyager, like automation software, is a comsumer of the horizon ! In anycase you can create manually in a simple excel file or using a smartphone application dedicated to horizon or one of the planetarium around. Interpolations between points are done directly from Voyager during the import if necessary.
