Dragscript Connect flat device/Open flat device issue
Leo,
I was doing a new dragscript and while testing it I found out that the command Open flat device cover does not work unless the whole setup is connected.
What I mean is that if you execute the command Connect Flat Device #x, give it a few seconds and then run the Open flat device cover, nothing will happen. On the other hand, if I have the whole setup connected, the Open flat device cover command works. My flat device is the arduino flatdevice.
Is there anything that I am missing?
Miguel
Dear Miguel,
Like I wrote more than one time support is not allowed in forum. If you need support or think Voyager have a bug or whatever else you think not work good in Voyager use support and not forum.
Please send to support evidence of your problem with logs, the dragscript used cleaned of personal data like email, password etc …
Leonardo Orazi
