DragScrit to test unguided exposure in various point of the sky
Like the object … i wrote a DragScript to test tracking for unguide exposure for a friend with a GM mount. I sharing with you.
This script using a counter that increase by 1 and looping in a series of skypoint where do 300,600,900s shot and then go to next point. In the attached example there are 3 points and after end, but you can add how many point you need.
Voyager using ALT/AZ mount goto to better cover all the sky.
I hope someone can found it useful or interesting for know the big power of DragScript.
TestTrackInTheSky.vos (30.2 KB)
1   - 	Start: Events At Start are ENABLE
2   - 	Script
3   - 		Block: INIT
4   - 			Counter: Position - Init Value = 0
5   - 		Block: GOTO TO SKY POINT
6   - 			Update Counter: Position - Offset by 1
7   - 			DO IF COUNTER VALUE: Position is Equal to 1
8   - 				Goto ALT/AZ: ALT 45 - AZ 45 - FC: False
9   - 				Goto Block: SHOT STUFF
10  - 			DO IF COUNTER VALUE: Position is Equal to 2
11  - 				Goto ALT/AZ: ALT 60 - AZ 60 - FC: False
12  - 				Goto Block: SHOT STUFF
13  - 			DO IF COUNTER VALUE: Position is Equal to 3
14  - 				Goto ALT/AZ: ALT 75 - AZ 75 - FC: False
15  - 				Goto Block: SHOT STUFF
16  - 		Block: TERMINATE
17  - 			Goto End
18  - 		Block: SHOT STUFF
19  - 			Block: 300s
20  - 				Expose: Filter [0] [Filter Slot 0] - 300 [s] - Bin 1 - Full Frame - Light - Exp - 300
21  - 				Wait Time: 00:00:05 [hh:mm:ss] Interval
22  - 			Block: 600s
23  - 				Expose: Filter [0] [Filter Slot 0] - 600 [s] - Bin 1 - Full Frame - Light - Exp - 600
24  - 				Wait Time: 00:00:05 [hh:mm:ss] Interval
25  - 			Block: 900s
26  - 				Expose: Filter [0] [Filter Slot 0] - 900 [s] - Bin 1 - Full Frame - Light - Exp - 900
27  - 				Wait Time: 00:00:05 [hh:mm:ss] Interval
28  - 			Goto Block: GOTO TO SKY POINT
29  - 	End
30  - 	Events
