I enter targets via RoboTarget Manager. When I went to see my targets on RoboTarget, the Ephemeris Data is empty. Why ?
My setup is connected, the coordinates of my mount is entered correctly, the connexion will sky chart is functional …
I try this night and all is ok Thank you all !
On the Ephemeris graph, what is the purple Line ? There is two magenta lines (violet and pink). One is the Moon Phase, but whitch one and what is the other one ?
The one that’s the same for all targets (I think the magenta) is moon-phase; the other one is the distance between Moon and target; the higher the more separated.
Red area is where the constraints are not satisfied, cyano area is the altitude constraints if you have one, blu area is the actual running sequence for the target(if one)
