One “easy” target and another a bit more difficult. Easy is just a misnomer from London…
Main scope (152mm f/7.5 refractor) running under Advanced and acquiring L. Second scope (92mm f/5 refractor) linked under Array but triggered manually to image (for now ) and acquiring RGB using OSC camera.
Congratulations Roberto, all wonderful images !
First target is a really difficult target , so i’m not explain how you can take those results from your sky, so again congratulations !
I hope Voyager Advanced will help you to get the best.
Thanks for sharing.
I’m really amazed of what you can do from London. I live in central London and gave up trying to do narrowband (including with 3nm filters). I went the easy route : I moved my equipment to France and Spain.
