Here is how to get feedback from Talon ROR for your dragscripts
Yep, exactly the point.
If i’m in command of the observatory, it does not concern me a lot.
But i plan to fully automate the acquisition job, and need a confirmation when the roof is fully open in my dragscript.
That’s the exact purpose of Achille and it works here like a charm :smile:
Here is the binary release
Everything fails , all the time” is this famous quote from AWS CTO, Werner Vogels says the simple truth, your system or application will eventually fail , usually sooner than later !
For us the roof refuse to close tonight because i guess there was a switch failure !!!
Hopefully the combinaison of gotsx, achille and dragscript was smart enought to raise the alert (SIP INVITE).
Here is the log transcript of clandestine:
2020/11/19 01:12:41 INFO      Run Action => Parking
2020/11/19 01:12:41 SUBTITLE  Parking Mount
2020/11/19 01:12:41 INFO      Mount Parking ...
2020/11/19 01:14:00 INFO      Mount Parked
2020/11/19 01:14:00 INFO      Mount Tracking OFF
2020/11/19 01:14:00 EVENT     Parking Mount Done
2020/11/19 01:14:00 INFO      Action Time [PARK_MOUNT] => 1 [m] 18 [s]
2020/11/19 01:14:00 INFO      Action Time Mobile Mean [PARK_MOUNT] => 0 [m] 34 [s]
2020/11/19 01:14:00 EVENT     Instruction [166]=> IF OK
2020/11/19 01:14:00 EVENT     Instruction [167]=> Update String: RoofOperationSafe - "YES"
2020/11/19 01:14:00 INFO      Run Variable => Update String: RoofOperationSafe - "YES"
2020/11/19 01:14:00 EVENT     Instruction [168]=> Wait Time: 00:00:10 [hh:mm:ss] Interval
2020/11/19 01:14:00 INFO      Run Action => Wait Time: 00:00:10 [hh:mm:ss] Interval
2020/11/19 01:14:00 SUBTITLE  Wait Time
2020/11/19 01:14:00 INFO      Time Wait Start @ 19-11-2020 01:14:00
2020/11/19 01:14:00 INFO      Time span of 00:00:10 - Wait End @ 19-11-2020 01:14:10
2020/11/19 01:14:10 EVENT     Wait Time Done
2020/11/19 01:14:10 EVENT     Instruction [169]=> External Script: C:\Users\***\Documents\Voyager\Command\achille.exe switch mountAtPark; StringCheck=OK, switch confirm that mount is parked
2020/11/19 01:14:10 INFO      Run Action => External Script: C:\Users\***\Documents\Voyager\Command\achille.exe switch mountAtPark; StringCheck=OK, switch confirm that mount is parked
2020/11/19 01:14:10 SUBTITLE  External Script
2020/11/19 01:14:10 EVENT     Starting Executable (achille.exe) => C:\Users\***\Documents\Voyager\Command\achille.exe
2020/11/19 01:14:10 DEBUG     Arguments => switch mountAtPark
2020/11/19 01:14:10 DEBUG     Wait for finish with Kill Option for timeout => 1000[ms]
2020/11/19 01:14:10 INFO      Action Time [ATOMIC_WAIT_FOR_TIME] => 0 [m] 10 [s]
2020/11/19 01:14:10 INFO      Action Time Mobile Mean [ATOMIC_WAIT_FOR_TIME] => 0 [m] 54 [s]
2020/11/19 01:14:10 DEBUG     EXEC Output :
Nope!
2020/11/19 01:14:10 EVENT     EXEC finished OK
2020/11/19 01:14:10 WARNING   ERROR (FINISHED) External Script Ret Check KO
2020/11/19 01:14:10 INFO      Action Time [ATOMIC_RUN_EXTERNAL] => 0 [m] 0 [s]
2020/11/19 01:14:10 INFO      Action Time Mobile Mean [ATOMIC_RUN_EXTERNAL] => 0 [m] 2 [s]
2020/11/19 01:14:10 EVENT     Instruction [170]=> IF OK
2020/11/19 01:14:10 EVENT     Instruction [172]=> IF ERROR
2020/11/19 01:14:10 EVENT     Instruction [173]=> Update String: RoofOperationSafe - "NO"
2020/11/19 01:14:10 INFO      Run Variable => Update String: RoofOperationSafe - "NO"
2020/11/19 01:14:10 EVENT     Instruction [174]=> External Script: C:\Users\***\Documents\Voyager\Command\gotsx.exe ; StringCheck=OK
2020/11/19 01:14:11 INFO      Run Action => External Script: C:\Users\***\Documents\Voyager\Command\gotsx.exe ; StringCheck=OK
2020/11/19 01:14:11 SUBTITLE  External Script
2020/11/19 01:14:11 EVENT     Starting Executable (gotsx.exe) => C:\Users\***\Documents\Voyager\Command\gotsx.exe
2020/11/19 01:14:11 DEBUG     Arguments =>
2020/11/19 01:14:11 DEBUG     Wait for finish with Kill Option for timeout => 1000[ms]
2020/11/19 01:14:11 DEBUG     EXEC Output :
Get status from TheSkyX: Is mount at Park1 position ?
OK, Mount is parked
2020/11/19 01:14:11 EVENT     EXEC finished OK
2020/11/19 01:14:11 EVENT     External Script Done, Ret Check OK
2020/11/19 01:14:11 INFO      Action Time [ATOMIC_RUN_EXTERNAL] => 0 [m] 0 [s]
2020/11/19 01:14:11 INFO      Action Time Mobile Mean [ATOMIC_RUN_EXTERNAL] => 0 [m] 2 [s]
2020/11/19 01:14:11 EVENT     Instruction [175]=> IF OK
2020/11/19 01:14:11 EVENT     Instruction [176]=> Send Email: ***@*****.*** - Confirm Park1 position - We got confirmation from theSkyX
that t ...
2020/11/19 01:14:11 INFO      Run Action => Send Email: ***@*****.*** - Confirm Park1 position - We got confirmation from theSkyX
that t ...
2020/11/19 01:14:11 SUBTITLE  Send Email
2020/11/19 01:14:11 EVENT     Try Send Mail To =>  ***@*****.*** ; Subject => Confirm Park1 position
2020/11/19 01:14:11 INFO      Mail Sent
2020/11/19 01:14:11 EVENT     Send Email Done
2020/11/19 01:14:11 INFO      Action Time [ATOMIC_SEND_MAIL] => 0 [m] 0 [s]
2020/11/19 01:14:11 INFO      Action Time Mobile Mean [ATOMIC_SEND_MAIL] => 0 [m] 0 [s]
2020/11/19 01:14:11 EVENT     Instruction [177]=> IF ERROR
2020/11/19 01:14:11 EVENT     Instruction [179]=> Block: Close the roof
2020/11/19 01:14:11 EVENT     Instruction [180]=> DO IF STRING VALUE: RoofOperationSafe is Equal to "YES"
2020/11/19 01:14:11 INFO      Run Condition => DO IF STRING VALUE: RoofOperationSafe is Equal to "YES"
2020/11/19 01:14:11 WARNING   Check String .. NOT MATCH != NO
2020/11/19 01:14:11 EVENT     Instruction [194]=> Block: CloseRoofAlert
2020/11/19 01:14:11 EVENT     Instruction [195]=> Send Email: ***@*****.*** - Close Roof ALERT - For unknown reason kosmodrom
did not ma ...
2020/11/19 01:14:11 INFO      Run Action => Send Email:  ***@*****.*** - Close Roof ALERT - For unknown reason kosmodrom
did not ma ...
2020/11/19 01:14:11 EVENT     Try Send Mail To => ***@*****.*** ; Subject => Close Roof ALERT
2020/11/19 01:14:12 INFO      Mail Sent
Hi everyone,
I just read this thread with interest as I’m also a Talon 6 user at e-eye and taking my first steps with Voyager, after using SGP for the first year.
Whilst I can open the roof using dragscript, I’m getting an error message when dragscript tries to close the roof. It does close eventually (I have a 60 sec timing delay set in the Talon driver).
I’m interested in trying the Achille solution and would also be grateful for an short example of how to implement it in practice. Thanks HoxCa for your hard work and contributions to the project!
Regards,
Andy
hello Andychess,
I’ve never experienced an error message when closing the roof with my dragscript…
Could you post a screenshot of your Talon and Voyager configuration ?
FYI: Achille is just used to be sure that we are in a safe condition before operate the roof and did not interfere with the roof itself. Achille is used just to check the talon switch status from dragscript.
Regards,
HoxCa
IMG_6104 IMG_6105 IMG_6106
I get a general error when I try to view the Talon Ascom properties.
The error message when I close the roof is shown in the screenshot.
I dont know the system you talk about bout for the error…coming from ASCOM chooser not from Voyager
Latebinding is something related to ASCOM version, COM version, ASCOM or Driver installation (missing or damaged).
if you driver delay is so big try to increase the time for command here (Waiting time after Command before starting read status) default is 4s:
https://wiki.starkeeper.it/index.php/Dome_Setup
Sorry for write in this topic.
Hi (again) Leonardo,
The Ascom problem is unrelated to Voyager. I included the picture just in case HoxCa could offer a solution. (We are both at e-eye).
Not sure if you‘re familiar with the background, but e-eye provide a unit with its own ROR and Talon 6 controller. Everything else is the responsibility of the client.
As a result, I know very little about Talon, compared to other components of my setup.
Thanks for the tips. I‘ll investigate them tomorrow.
Andy
BTW, the reason that I‘m moving to Voyager at all, is that you allow such fine control of the details of the setup.
The killer-feature for me is the focus control. SGP often crashes due to a 1 unit difference in commanded and actual position of my Planewave focuser.
A bit off-topic, I know. But a big thumbs up for Voyager and its flexibility. The roof fix is just one example of this!
hello Andy,
Your screen capture looks weird.
Have you check for the correct operation of the talon roof directly from the voyager command panel without dragscript ?
Seems to be a misconfiguration somewhere on your side, i will post you some screenshot of our roof with voyager tomorrow.
I don’t know what you are doing with the dragonfly test script here…
Feel free to DM me if you want.
Regard,
HoxCa
Hi HoxCa,
I reinstalled the Talon driver and ran it as admin and the problem with the Ascom properties was solved.
Also, thanks to Leonardo’s tip, the roof now closes without the error message.
Due to Corona, the guys at e-eye had to build my telescope for me, which meant I didn’t reallly understand the roof at first and had two closures onto my scope(!) which meant that I didn’t trust the roof for a long time.
I’ve now spent some time reading the manual and testing the setup, so that I feel confident to implement a few protections such as the loss of Internet and Loss of Connection. Eventually, I hope to deal with the weather based closures through Voyager as I don’t find the cloud sensor on the Cloudwatcher reliable enough at the moment.
I still need to figure out why I can’t run the Dragonfly scripts from Voyager, but that’s another story. The test script should just close a relay, but for some reason doesn’t.
All the best,
Andy
If you call a program try to specify the full path in the script
I finally solved the problem (I hope). I was running Voyager as administrator. When I changed this, the script worked.
Hmm! I just noticed that Voyager needs to run as admin. The Dragonfly doesn’t seem to work when run as admin. Can you suggest any other ideas?
Voyager is installed to work like admin and this is the right way to work with it.
DragonFly have not problem to run with Voyager. Do not jump from admin / not admin without restart PC or you will cannot connect what before was connected fine.
