Is it possible to add an inject focus on an array system while it’s running? I’m finding the normally used inject focus button does not work.
Gabe
Gabe
Inkect focus is reserved to normal sequence … i will add to array sequence
Sounds great! Thanks Leo!
Gabe
Is there any update on this? Or, may I ask how you guys handle Array focusing frequency?
I set my Array to focus every 30mins or so; however in the beginning of the night the weather drops fast, and I think I need to focus more frequently; I noticed HFDs of my last vs. 1st image before re-focusing varies a lot. Later in the night the temperature is more stable, so I think I can even focus less frequently. Right now Array can only focus at a set period of time (or equivalent # of frames). How hard is it to implement temperature-based re-focusing trigger? I understand we have multiple temperature sensors in Array system, but how about just rely on Master system, and trigger focus accordingly?
Yizhou
Is on the to-do list.
Focus on temperature is just problematic in terms of temperature reference (you have multiple systems).
Probably can be introduced using the temperature system in the Master node.
