Hi Leo,
I am new to Voyager. I had a dragscript run the other night and there was an exit/shutdown because of a low Alt. condition reported (under 30 deg.) This was clearly not the case. The target / scope was pointed well above that lower limit. I believe there is some type of bug causing the reported location Longitude incorrectly.
Problem/ bug seems to be that the Longitude is reported with the Latitude value:
Data used for Altitude check => Lat 39 46 24.00 Long -39 46 24.00 RATarget=06 33 33.775 DECTarget=04 52 31.56
In SetupForm for my MOUNT I am using TheSky64 and the mount driver is Astrophysics V2
Out of 4 Nights running this error happened on just one night.
Let me know what you think may be the cause.
I had this same issue. I uninstalled ASCOM 6.5, build 6.5.1.3234 and then reinstalled it and the issue was fixed.
I’m using TSX64 Build 13210, APCC v1.7.1.5 (yes I know its old) and AP V2 driver V5.40.01.
Mike
I had that happen once too where it used latitude coordinates for longitude and it shut down early. I’m using TheSkyX with a Paramount. I am now using the override coordinates and it hasn’t happened again. Weird glitch.
