More Voyager and The Sky X
I have voyager set to work with TSX, and it opens TSX and device connect fine. I can’t figure out how to home the mount and wait for darkness etc from inside voyager. Also I am using Interactive Astronomy SkyRoof and that also connects but how do I tell it to open or close the roof from inside voyager?
Welcome,
for telescope commands:
https://voyager.tourstar.net/index.php?title=Command_Window#Mount
if you want to waiting darknees you must use sequence and put inside the time needed:
https://voyager.tourstar.net/index.php?title=Sequence_Configuration#On_Start_Tab
or using DragScript you can use the block dedicated to this task:
https://voyager.tourstar.net/index.php?title=DragScript_Elements#Timing
or personalize in DragScript the Session block (Sequence):
https://voyager.tourstar.net/index.php?title=DragScript_Elements#Session
For the SkyRoof you can use ASCOM driver if they developed:
https://voyager.tourstar.net/index.php?title=Dome_Setup#Dome_Choice
or use external script or if roof have a I/O external relay you can use Viking with a compatible I/O card:
https://voyager.tourstar.net/index.php?title=Viking
