NGC7000 & Pelican
Hi all,
https://i.ibb.co/6JKSjD5/NGC7000.jpg
one my first photos.
ofc with Voyager!
taken from Umbria, IT (near Todi)
Tak FSQ 85
QHY268M
LRGB about 1h each
I have also 1h of H-Alpha but haven’t used it in this picture (should I?)
any input is appreciated!
Hi Valerio,
I was born near Todi (Torri di Gualdo Cattaneo) … great place !
Let me know where you have taken the image, i’m interested on this.
Really nice image, my suggestion is to change the white point … you have lost a lot of red. This usually happens when you use a wide colored area for white balance or the wrong place (not gray/black place).
Hi Leonardo, I was on vacation with friends, we booked the property for 2 weeks here and I tried to take some shots. As soon as they went to sleep… I turned off all the external lights and started taking pictures! :grinning_face_with_smiling_eyes:
this is the location Google Maps
thanks for the suggestion, I had the same impression…
if you also use pixinsight can you help me undestanding “when” I should do that?
After integrating all RGB channels I did
  • background neutralization
  • PCC (photometric color calibration)
  • SCNR (Subtractive Chromatic Noise Reduction) to remove green
I’m just learning PixInsight and I’m unsure what went wrong in my process!!
Really nice place … thanks.
PCC in this area can give to you this kind of result. You can proceede only with the background neutralization choosing a right black area where the signla can be considered null.
If you want to share in private the color combination before processing I’m sure I can take a little video to help. In private.
Otherwise here there are a lot of talented AP can help
I guess I’ll try to reprocess soon and I’ll write you in case. that’s very kind of you.
have a nice day!
