I just started using Voyager and so far, so good except when I start a sequence using On the Fly, PhD connects but doesn’t begin auto guiding. I am able to manually start it from the PhD interface. It doesn’t show the guiding graph in the status bar, although it does have a green box next to “guide.” Also it failed to resume guiding after a meridian flip. Thought I had the settings right, but obviously I don’t. Thanks for your help!
Welcome … you must check flag calibrate, guiding, dithering in Sequence configuration to allow use of this features with PHD2. This is not automatically only if you have PHD2 configured.
https://voyager.tourstar.net/index.php?title=Sequence_Configuration#Guide.2FDithering_Tab
