Plate solving issue
I had my first run with trial subscription last night. For most part it went alright except one issue that I couldn’t solve and had to work around it.
My plate solve was failing all the time when i had Skyx Linked in my plate solve and blind solve settings. I tried plate solving directly from SkyX and that would be successful.
As a work around i changed the settings to Pinpoint and it was working as expected.
What things should I check to debug through this.
Capture
In general, I am using Skyx Add on for ccd and guiding and wanted to use skyx for plate solving too.
Regards
Raki
Seems have you used the green button here ?
https://voyager.tourstar.net/index.php?title=AutoFocus_Setup#Point_Closest_Focus_Star_with_RoboStar
Yes, you are right. Thank you for pointing this out.
