Hi, I’m new to Voyager and so far I like what I see. But while setting up my camera, ASI 183MC Pro, I noticed a field called “SensorType”. Clearly my camera is color so I picked color. When I do, my filter wheel disappears and I don’t see any other location in the SetupForm for a filter wheel. But if I leave it as monochrome, then I can setup my filter wheel. So how would I setup my OSC camera with a filter wheel? Do I leave my SensorType to monochrome or should it be color? Thanks in advance.
Select Monochrome, then you can use the filter wheel. The selection does not effect your color camera.
