Hi all, I’m sure there’s a very simple answer to this, but I’m having trouble finding it.
I’m setting up my gear after rebuilding my computer, and I can’t find the ZWO ASCOM filter wheel in the ASCOM chooser. When I choose ASCOM Filter wheel and click the ASCOM button to the right, I can’t see any ZWO driver.
For the camera I’m using the ASI Camera V2 driver (which I think came in the ZWO camera driver setup I downloaded today).
There is also a ZWO ASCOM driver that you need to install, which from memory is an all in one, you can use the camera, filter wheel, focus motor etc with the ASCOM driver, but you will want to use the native V2 driver for the camera instead of the ASCOM driver, and ASCOM for the filter wheel.
Once you have it connected, don’t bother to set up the filters in the ASCOM driver, edit the Voyager filter setup with the edit button below the filter information section on the left of the screenshot you have posted.
Actually yes, I found that site just now too, I wonder if ZWO are in the process of moving websites, ZWOastro.com make much more sense as a URL than astronomy-imaging-camera.com.
