Sync Mount After Plate Solve?
Hello,
Plate Solve 2 works great. When you plate solve actual coordinates does it also sync the mount? If not how can I sync my AP mount when I plate solve?
thanks
By default sync is done after each platesolve. If you have model you can choose to use or not sync in voyager. Depends if your mount driver allow adding point to model when a sync was done.
In the attached image you see the flat to disable sync. The image is also a display of default setting in box Management.
Your mount allow sync, this mean if you doesn’t check flag in red box all is ok.
