I’ve been having a lot of trouble getting my camera to cool fast enough (always hits timeouts, often gets “stuck” at low cooling power with high temp.
ASI 2600 MM Pro. I can definitely cool the camera to the target temp, as it works just fine in a minute or two in other software. I’ve tried setting Cooldown time to very small #'s and turned firmware cooling both off and on. Not sure what I’m doing wrong but camera always takes 10-20 minutes to reach target temp and often just stops cooling way above the set point with power at low values (40% range).
Suggestions?
