Voyager 2.0.11 Release
https://software.starkeeper.it/index.php/download/
:us: In this version:
NEW => Added support for Dome ScopeDome control LocalServer with Sync Scope
NEW => Added New DragScript Dome Slave On block
NEW => Added New DragScript Dome Slave Off block
NEW => Added New DragScript Dome Goto Azimuth block
NEW => Added New DragScript Dome Goto Home block
NEW => Added New DragScript Dome Parking block
NEW => SCObservatory Array System added new type of Sequence using RoboFire LocalField instead of RoboFire with RoboStar
MOD => Modified system of connection setup, introduced added for in process of the Dome
MOD => The available Update form will be closed automatically after a pre-set time if not used
BUG => DragScript block Waiting for Astronomical Night did not accept values ​​up to 180 °
BUG => Possible failure of AutoFocus (VCurve and LocalField) due to lack of memory in the star recognition system following memory leak
BUG => For ASCOM Rooms managed directly by Voyager Possible Error in Saving the FIT File or black image due to memory failure due to memory leak
BUG => Correct block configuration window title Execution of external scripts
:it: in questa versione:
NEW => Aggiunto supporto per controllo Dome ScopeDome LocalServer with Sync Scope
NEW => Aggiunto Nuovo blocco DragScript Dome Slave On
NEW => Aggiunto Nuovo blocco DragScript Dome Slave Off
NEW => Aggiunto Nuovo blocco DragScript Dome Goto Azimuth
NEW => Aggiunto Nuovo blocco DragScript Dome Goto Home
NEW => Aggiunto Nuovo blocco DragScript Dome Parking
NEW => SCObservatory Array System aggiunto nuovo tipo di Sequenza che usa il RoboFire LocalField invece del RoboFire con RoboStar
MOD => Modificato sistema di connessione setup , introdotta aggiunta per in process dei Dome
MOD => Il form di Update disponibili verrà chiuso in automatico dopo un tempo prestabilito se non utilizzato
BUG => Blocco DragScript Attendi Notte Astronomica non accettava valori sino a 180°
BUG => Possibile fallimento dell’AutoFocus (VCurve e LocalField) per errore di mancanza memoria nel sistema di riconoscimento stellare a seguito di memory leak
BUG => Per le Camere ASCOM gestite direttamente da Voyager Possibile Errore nel Salvataggio del File FIT o immagine nera per errore di mancanza memoria a seguito di memory leak
BUG => Corretto titolo finestra configurazione blocco Esecuzione Script Esterni
