https://software.starkeeper.it/index.php/download/
In this version:
NEW => New general DragScript option to enable or disable event management before starting the script itself and avoid rebounds / activation delays in some setups
NEW => Added context menu item in the DragScript section to start the script by forcing event handling to Disabled
NEW => Added command line management of Voyager executable to automatically launch dragscript Es. Voyager2.exe /run:"C:\documents\pippo\voyager\script\script.vos "
NEW => Added New block DragScript Guide Acquire Star
NEW => Added New DragScript block Start Guide
NEW => Added New block DragScript Guide Stop
NEW => Added New block DragScript Guide Dithering
NEW => Added new block type for the management of numerical variables or string
NEW => Added new block for the creation of customizable Numerical Counters
NEW => Added new block for editing of customizable Numerical Counters
NEW => Introduced new focus subframe exposure calculation system named SmartFlux to optimize large flux variations following the star selection in some setups
NEW => Added new conditional block for the verification of the customizable Numerical Counters
NEW => Added new block for creating customizable strings
NEW => Added new block for editing customizable strings
NEW => Added new conditional block for the verification of customizable strings
NEW => It is now possible to store the return text from an external script in a container DragScript string for the control of equality or presence
NEW => Added choice to Dithering each X shot in Sequence
MOD => In the DragScript the Start Block now continues configurable general options
MOD => Modified DragScript Camera Expose block to manage ROI%
MOD => In the CameraShot action in OnTheFly it is now possible to indicate the ROI%
MOD => In the FLAT action it is now possible to indicate the ROI%
MOD => Forced Maxim to always assume the focal length set in Voyager
MOD => Expanded frame width of RoboFire VCurve in settings from 512 to 1024 pixels as maximum settable
BUG => For color cameras or DSLRs, the default values that can be set in the RoboFire LocalField configuration window were not read and the time of 1s was always used to bin1
BUG => It was not possible to use the RoboFire LocalField without setting the VCurve values of the First Light, now it is no longer necessary to realize the first light wizard for using only LocalField but you can directly set the value of the step sample
in questa versione:
NEW => Nuova opzione generale di DragScript per abilitare o disabilitare la gestione eventi prima dell’avvio dello script stesso ed evitare rimbalzi/ritardi di attivazione in alcuni setup
NEW => Aggiunta voce di menù contestuale nella sezione DragScript per avviare lo script forzando la gestione eventi in Disabilitata
NEW => Aggiunta gestione riga di comando dell’eseguibile di Voyager per lanciare in automatico dragscript Es. voyager2.exe /run:“C:\documents\pippo\voyager\script\script.vos”
NEW => Aggiunto Nuovo blocco DragScript Guide Acquire Star
NEW => Aggiunto Nuovo blocco DragScript Guide Start
NEW => Aggiunto Nuovo blocco DragScript Guide Stop
NEW => Aggiunto Nuovo blocco DragScript Guide Dithering
NEW => Aggiunto nuova tipologia di blocco per la gestione di Variabili numeriche o stringa
NEW => Aggiunto nuovo blocco per la creazione di Contatori numerici personalizzabili
NEW => Aggiunto nuovo blocco per la modifica di Contatori numerici personalizzabili
NEW => Introdotto nuovo sistema di calcolo del tempo esposizione subframe di fuoco denominato SmartFlux per ottimizzare larghe variazioni di flusso a seguito della selezione stellare in alcuni setup
NEW => Aggiunto nuovo blocco condizionale per la verifica dei Contatori numerici personalizzabili
NEW => Aggiunto nuovo blocco per la creazione di Stringhe personalizzabili
NEW => Aggiunto nuovo blocco per la modifica di Stringhe personalizzabili
NEW => Aggiunto nuovo blocco condizionale per la verifica delle Stringhe personalizzabili
NEW => E’ ora possibile memorizzare il testo di ritorno da uno script esterno in un contenitore Stringa DragScript per il controllo di uguaglianza o di presenza
NEW => Aggiunta possibilità in Sequenza di eseguire il dithering ogni X pose
MOD => Nel DragScript il Blocco Start ora continue opzioni generali configurabili
MOD => Modificato blocco DragScript Camera Expose per gestire il ROI %
MOD => Nell’azione CameraShot in OnTheFly è possibile ora indicare la ROI %
MOD => Nell’azione FLAT è possibile ora indicare la ROI %
MOD => Forzato Maxim ad assumere sempre la focale impostata in Voyager
MOD => Ampliato frame width del RoboFire VCurve nei settaggi da 512 a 1024 pixel come massimo impostabile
BUG => Per le camere a colori o DSLR non veniva letti i valori di default impostabili nella finestra di configurazione del RoboFire LocalField e veniva sempre usato il tempo di 1s a bin1
BUG => Non era possibile usare il RoboFire LocalField senza impostare i valori di VCurve della First Light, ora non è più necessario realizzare la first light wizard se si vuole usare solo il Localfield ma si può impostare direttamente il valore degllo step sample
