Just to play with it I set up this script based on Betelgeuse rising past 30 degrees then 33 degree. It was at 27 degrees at the time. It recognizes the correct current altitude when both the Wait statements run as shown below, but then immediately fires the next action showing a much higher altitude. Anyu suggestions? I tried to make sure my current location was correctly set in the ASCOM driver and in TSX. I know I said I wouldn’t ask a question today but this is just puzzling me too much!
13:18:58 388 - Run Action => Wait Altitude: >= 30 [°] - ( RA 05 56 11 - DEC 07 24 25 ) - Timeout 00:00:00 [hh:mm:ss]
13:18:58 581 - Waiting Altitude Target 27 10 07.91 vs. Request 30 00 00.00 *
13:19:09 679 - Waiting Altitude done … Target 49 47 22.52 vs. Request 30 00 00.00
13:19:09 691 - Instruction [5]=> Expose: Filter [0] [Filter Slot 0] - 10 [s] - Bin 1 - Full Frame - Light - Exp - None
13:19:09 707 - Run Action => Expose: Filter [0] [Filter Slot 0] - 10 [s] - Bin 1 - Full Frame - Light - Exp - None
13:19:09 999 - Camera Expose : D:\ASI20494\Test\Exp_LIGHT__No_Filter__20190421_131909_994_W.FIT
13:19:10 019 - Dome Slave Manager : Dome Object is Null
13:19:10 457 - Exposing 10 [s] ; Filter=* No Filter ** ; Type=LIGHT ; Binning=1 ; ReadoutMode=Default
13:19:22 977 - Expose finished
13:19:22 997 - Download started
13:19:23 326 - Download finished
13:19:25 668 - File FIT Saved (Exp_LIGHT__No_Filter__20190421_131909_994_W)
13:19:25 680 - Camera Expose Done
13:19:25 689 - Action Time [ATOMIC_CAMERA_SHOT] => 0 [m] 15 [s]
13:19:25 706 - Action Time Mobile Mean [ATOMIC_CAMERA_SHOT] => 0 [m] 10 [s]
13:19:25 724 - Instruction [6]=> Wait Altitude: >= 33 [°] - ( RA 05 56 11 - DEC 07 24 25 ) - Timeout 00:00:00 [hh:mm:ss]
13:19:25 745 - Run Action => Wait Altitude: >= 33 [°] - ( RA 05 56 11 - DEC 07 24 25 ) - Timeout 00:00:00 [hh:mm:ss]
13:19:25 904 - Waiting Altitude Target 27 14 27.58 vs. Request 33 00 00.00
13:19:41 023 - Waiting Altitude done … Target 49 47 22.52 vs. Request 33 00 00.00
13:19:41 055 - Instruction [7]=> Goto End
