External script from UPS to trigger Emergency EXIT
Is it possible to have an external script trigger the Voyager Emergency Exit Event?
My UPS allows sending a .cmd file script before it triggers a shutdown (see attachment) in case of power outage. And it can do so based on a certain % of battery-time left.
Right now I have a relay connected to the UPS and Viking monitoring the status to trigger an Emergency Exit. But that does not take into account the available battery-life, so it’s guessing how long to wait before shutting things down (0s to be safe, 15m as ‘likely’, etc?).
The external script option in Dragscript and all other info in Wiki and forum assume the initial trigger to come from within Voyager.
Any suggestions welcome.
use the text safety monitor and read a file created by this cmd
https://wiki.starkeeper.it/index.php/Safety_Monitor_Setup#Text_File_Safe_Monitor
Select the emergency exit event mode:
https://wiki.starkeeper.it/index.php/Safety_Monitor_Setup#UnSafe_Signal_Management
Ah, through the safety monitor. That should work indeed. I’ll pursue that option. Thanks Leo.
