Last night I ran into a issue with the Voyager and my filter wheel. I have 15 filters! This was fine when I set my camera to Maxim DL - all 15 were available. However, I switched my camera to the native driver and the FW to ASCOM and after a Voyager restart I can only see/use 12. Also, there is no way to add more and the EDIT list only allows to edit the first 12.
The initial list of 15 filters was generated with “GET” when using Maxim DL. It seems the list was truncated to 12 after the reset. (BTW - Maxim DL auto populates all 15 filters from the same ASCOM driver.)
The error from the Dragscript was…
01:24:21 947 - Request 32 FLAT | | Bin=1 | ROI=64 | Mean ADU=32768 | Max Dev %=5 | EXP(2.5 - 10)[s] | Speed=Default | Readout=Default | Gain=0 | Offset=0
01:24:21 955 - Wrong Filter (index=12) - Skip this Element
01:24:21 989 - Request 32 FLAT | | Bin=1 | ROI=64 | Mean ADU=32768 | Max Dev %=5 | EXP(2.5 - 10)[s] | Speed=Default | Readout=Default | Gain=0 | Offset=0
01:24:22 034 - Wrong Filter (index=13) - Skip this Element
Help!
Frank
