I’ve tested voyager in real life with sequence and dragscripts in the last 2 nights.
\o/ This is an amazing software.
Interestingly there were some clouds into play !
Which demonstrate the already very good resilience of Voyager to adversity.
As “Werner Vogels” (CTO on Amazon) said “Everything fails all the time”.
I know that Voyager is built with the “design for failure” paradigm in mind.
I’ve searched in the documentation but could not find answers to a couple of cases.
So, you will find here my Absurd Hypothetical Questions
What if:
- My guiding of a 600s exposure loose it’s track
Is it possible to abort just the current exposure and continu normal sequence opération ?
Is there a way to abort the current exposure and do this automatically from sequence based on actual guiding deviation (abnormal peak in guiding, pass a specified threshold of a value in px or arcsec) ?
- Plate solving in sequence (from a dragscript) is simply impossible because there is clouds passing by
If there is no stars in the exposure for plate solve, there is no chance to solve. Is there a way to automate a pause before the next itération ? (like between 5/15 minutes, giving time for the sky to clear)
(without AAG).
- In the middle of the night something goes wrong, or i did not update one parameter before launching dragscript; subsequently dragscript is looping somewhere and try to recover. It need some manual adjustment in the dragscript.
Is there a way to pause a dragscript ? For correcting reload and resume the current dragscript.
- I want to pause the sequence after the current action
Is there a way to force the pause of sequence after the current action ?
Is there any documentation on the processing of the normal pause injection (when it would be done) ?
- My mount doesn’t clear the rollroof when it’s not parked
If the roof is open, and the mount is not parked; I would like to prevent any action on the roof (On the fly, Sequence or Dragscript) ?
We generally already have some safety mesure in place, but it would be as convient as the inverse option which prevent goto if roof is closed.
