My current multi target script uses a counter. This won’t work well for advanced.
I could use a couple full advanced Drag Script Examples to get me started.
Max
Max
Hi Max,
just replace the Sequence part of your DragScript with RoboTarget block.
Rowland have explained this on his blog:
https://tourstar.net/
Or use the example in our Wiki:
https://wiki.starkeeper.it/index.php/DragScript_Examples#Perpetual_Script_H24.2F7Days
I am trying to follow the logic flow. Does normal shutdown go to emergency exit?
Will all the notifications will show emergency shutdown messages?
Max
Yes, normal shutdown is done with a Raise of emergency exit.
The counter associated to the reason of shutdown allow to send different message if it is a real emergency event or a normal shutdown, see the image above.
Thanks !
Now I get it
Max
