After Startup Issues "Sound Preload" I loose the setup configuration
Hello,
I had the “Sound Preload” issue and solved as explained in the wiki. The problem I find is that after this I completely lost the setup configuration. Is it possible to recover it?
Jose
This issue could happen when you or os close Voyager with kill when OS saving the windows setting, so really a lot of combinations.
Anyway not related to the Voyager setup configuration but only to windows size and arrangements configuration.
Try to open the profile, probably already exists.
If the file are deleted there is not way to restore, just if you have a backup of the PC or backup of the Voyager directory in Documents folder.
