Apogee Camera conect?
To connect my Apogee U16 and filter wheel to Voyager I’m currently using Maxim Dl, it works fine. Is there an ascom driver that works for Apogee? If so, I can’t seem to find it… I would like to connect both without using Maxim Dl.
Thanks…
I have an apogee alta model and it works with voyager through own ascom drivers.
I can make them available if you want to give it a shot. Let me know
Best
Miguel
Miguel,
That would be great if you could. I have been searching for days trying to find them. It would be well worth a try. Do you know if the ascom driver will also support the apogee filter wheel? How can you makt them available?
Thanks, Paul
Miguel,
Thank you so much!!! I installed the ascom driver and it works perfectly with the camera and filter wheel…
A rare 2 clear nigjts ahead, you are a life saver…
Paul
Glad it worked out! Don’t forget to share a picture with that setup :wink:
Miguel
Thanks again Miguel…
I did have a small problem when I ran the first sequence in a drag script.
After installing the ascom driver and changing the camera setup, everything conected ok. I opened up the observatory and did a bunch of test shots using camera control in on the fly… Everything looked and behaved great… I ran a drag script with a sequnce in it for the veil. When the first 10 min sub came down, all the data looke like whole image was squished into the left half of the frame. The right half was blank. The second sub did the same thing so I aborted, did a 10 min sub using on the fly, and it was perfect… I disconnected everything, checked and re saved the sequence and the drag script, re connected everything and ran the drag script again. What ever it was, it fixed itself (I hate that) and the script ran all night, closed and shutdown the obs, and every sub looks great!
Ive got another clear night and everything is set up to run the same script. I cant believe I can get the the whole whitches broom on this chip using my 16 RC!
It looks promising…
Hi Miguel and Paul -
This might be a long shot, but came across this thread a few years later after starting with Voyager recently.
I am also looking for the Apogee ASCOM driver (for an Alta F16) for the option to take Maxim out of the loop. If either of you see this and can pass along the ASCOM driver you have found that works, would really appreciate it.
Thanks much,
Mark
If Maxim DL does not fit your needs, you can also use TheSkyX Camera Add-On for camera control in Voyager. This will allow you to use the Apogee camera directly.
