I have been using the Meridian Flip Mode = Manage with the ABORT Exposure if Meridian Flip Occurs outside Voyager option ticked with my AP1100GTO and APCC (which allows me to image with counterweights up automatically).
I cannot see the ABORT option in Array Sequence. Can I check Meridan Flip Mode = Manage and assume the above will happen?
In regular Sequece:
In Array Sequence:
Sequence in Array is absolutely different from Normal Sequence, so if you not found this mean not is implemented or isnt possible to implement. I suggest to you to work in a normal way with the meridian.
I’ll try to understand if is possible to add and how.
Ok; I’ll leave as Managed then. Will wait to hear from you Leo.
Sure Roberto, let me found time to check.
