I’ve just got myself a SA100 for a project to record spectra (multiple targets per session).
I am trying to work out if I can use Voyager to help automate this process.
If my setup is like this:
main scope + SA100 + cooled camera
guide scope + guide camera
Can I plate solve to a target using the guide scope?
Plate solving gets the target in the centre - can I get Voyager to move a set distance offset after the plate solve, as I need to get the star to the “side” to fit the spectra lines in?
Has anyone else tried using a SA100 with Voyager + automation?
You cannot target on object using guide scope plate solve, sorry lazjen.
If your mount allow modelling you can trust pointing.
Or you can use a 2 node array system configuring guidescope like master and SA100 like slave. This if they pointing in sync to the sky (mechanical alignment).
Ok, I read that page and missed that - thanks. I think I might be able to do it via modelling and pointing, plus this offset. It’ll take a bit of trial and error to sort it out, but it has a good chance to succeed I think.
