Base sequence trouble
I seem to be stuck at the starting line.
I am unable to add a base sequence in the RoboTarget Manager. I select my equipment profile and right click to select Add Base Sequence, which brings up the option to “select a sequence.” But when I click on the drop down menu next to “select a sequence,” nothing is there. I have a ton of sequences in the ConfigSequence folder of my main Voyager directory, but for some reason Voyager is not finding them. Can anyone tell me what I might be doing wrong?
I had the same problem. The sequences have to be created in the same profile used for RoboTarget or they won’t show.
Chris
Thank you, Chris. I did a little experimentation and found that sequences will appear in the base sequence list if they are top-level in the ConfigSequence folder but not if they are in a subfolder. Unfortunately for me, I keep my sequences sorted by telescope in subfolders for wide, medium, and close-up shots of various targets. I will ask Leo if he can allow base sequences to be found within subfolders.
You can select only base sequence related to the profile and not the others , this is not a bug but this is a safety thing.
You cannot use sequence outside the default folder because from remote there is not concept of folder to define.
Got it. Thanks, Leo.
