Camera Setup vs Sequence Settings
When using the “ASI Camera” or “ASI Camera v2” direct driver, which settings take precedence … SetupForm or the Sequence? Does one override the other?
My understanding is that settings in sequence will take priority, I.E. if you have gain 0 offset 50 set in the camera setup tab, you will get those settings (Focus exposures, plate solving etc) unless it is specified elsewhere such as in a sequence file, or a dragscript expose command.
Appreciate that … If I got more than 1 night a month right now, I could get all this tested out. Hope your having better weather than I.
