Camerashot Error = 212
Last night I received a Camerashot Error = 212 when imaging within a sequence in Voyager.
My camera was set to TSX, and in TSX is configured to the Ascom driver for a QHY268. All was working earlier in the session.
Is there a list of error codes that are available to provide any detail.
Thank you in advance !
Matt
Hi Matt,
we do not offer support by forum , for official support please refer to what in this link:
About your question you must refer to TheSkyX support because error coming from TheSkyX.
Here the list of TheSkyX errors:
https://www.bisque.com/wp-content/x2standard/sberrorx_8h_source.html
I suggest to not use TheSkyX for manage this camera (if you can) , there is native support for QHY CMOS in Voyager.
Thanks for the info. I will send to the support link next time.
Matt
212 is a catch all SkyX “Process Aborted” error and doesn’t help much in finding the source.
lists all the error codes. I have seen it related to camera function on a few occasions. Are you able to take images in SkyX Camera Add On including sub-frames and binned full frames and sub-frames using the same camera selection? Check you are able to take short duration frames too … say 0.1 seconds.
