Change filter position with Dragscript
Just switched over to a mono camera and filters, after I had dragscripts dialed in . . .
Is there a way to change the filter position without taking an image? I just want to make sure I have the dark filter in position on initialization while it waits for dark. -to minimize dust on my filters.
Thanks!
if you use the Good Night block in DragScript at shutdown you have an option to select the filter to leave selected in the wheel. Otherwise do a dummy exposure of 0.1s
