A shot of C/2022 E3 just past perihelion on the morning of Friday 13th (!) from a very windy London. Just an 1hr made 2X by Voyager Array!
Full resolution:
https://www.astrobin.com/orh2lu/D/
Full resolution:
Very nice Roberto. Twin scopes identical or different ?
Hi Mike
A 6” refractor acquiring L at 1290mm and another 92mm doing OSC at 490mm.
Lovely Roberto!
I shot E3 on 6 Jan. 1200 mm. They look like twins…
Need to check your shot Jon. Must be gorgeous!
Great image! I plan to image the comet next weekend, I hope it gets bright enough to see it naked eye.
I am always impressed with the images you manage to pull from London ![]()
Thank you José! Post your results here if you can.
I will, Actually I will use an array, FSQ106 + RedCat51, I am very impressed with how easy is to use multiple telescopes with Voyager
