Greetings to all colleagues! How to effectively organize dithering in Voyager when using two telescopes simultaneously?
CS, Oleksiy
Check the Guide/Dithering tab of Array Sequence and select the dithering as you need:
Voyager dithering in Array is synchronized for sure, which is the ones method that do minor overhead depends on shot lenght in the various node, so you must decide for each single Array Sequence.
Other users can write their experience about
Thank you very much for the explanation Leo!
