The Sequence drag script element has a control called start immediately and Finish with Astronomical night. This control has an offset. Does a positive or negative offset allow the sequence to run longer than the Astronomical twilight end time?
yes you can use for this
A positive number causes the sequence to run longer and will finish after astronomical twilight.
