An example on how to use the environment variables managed by Voyager internally and ready to use in your DragScript.
In this case we use the Emergency variables:
- $$EMEVENT_EXIT_LASTREASON
- $$EMEVENT_EXIT_LASTTIME
- $$EMEVENT_SUSPEND_LASTREASON
- $$EMEVENT_SUSPEND_LASTTIME
and the Sequence Fail Status variable:
- $$SEQUENCE_FAIL_STATUS
A DragScript to send more info on exit status and on sequence error:
2 - Script
3 - Sequence: Interval of 01:00:00 [hh:mm:ss] - C:\Users\pegas\OneDrive\Documenti\Voyager\ConfigSequence\TestUnguidedNoPlateSolve.s2q
4 - If Error
5 - Send Telegram: Sequence Internal Error Code:.##VAR-$$SEQUENCE_FAIL_STATUS##..##NOW##.
6 - End
7 - Events
8 - Emergency Suspend: Wait Resume for a time interval of : 00:05:00 [hh:mm:ss] - On Resume Timeout End DragScript
9 - Remark: SUSPEND
10 - Send Telegram: Suspend Info:.##VAR-$$EMEVENT_SUSPEND_LASTREASON##..Suspend Date Time:.##VAR-$$EMEVENT_SUSPEND_LASTTIME##
11 - Emergency Resume
12 - Remark: RESUME
13 - Emergency Exit
14 - Remark: EXIT
15 - Send Telegram: ##VAR-$$EMEVENT_EXIT_LASTREASON##.##VAR-$$EMEVENT_EXIT_LASTTIME##
The script:
UsingEnvVariableInSignalMessage.chg.vos (17.5 KB)
Configuration of Send Telegram Block for Sequence:
Configuration of Send Telegram Block for Emergency Exit:
Generally to print content of a variable in a text press the button Variable and after the char - and ## insert the name of variable.
More info on Environment Variables here:
https://wiki.starkeeper.it/index.php/DragScript_Environment_Variables
