Exoplanet transits
Hello all
Is some script - procedure/guide flow that you use specifically for Exoplanet transits?Or just the research & survey ?
Best Regards
Nikos
Hi Nikos,
for exoplanet research your can choise if user the procedure in research system or better i reccomended you to create a personal sequence and put all in drag-script. If you need a great precision pay particular attention to focus minus possible during the sequence and time position of flip of mount if you have german mount
Giulio Scarfi K78
Thanks, Giulio
So If I am correct you use this? Correct?
There is no anything else (cause I thought I read in an older post some section for exoplanets)
here wiki about Resear & Survey:
