Our job is to keep Leonardo busy so here is another one
When creating the Array sequence, I’d love to have it automatically load the PA from Roboclip. This is currently handled in single system without problem, but I wonder if it’s difficult at all to load that in Array Sequence as well. It would be really helpful so I won’t worry forgetting changing the PA manually.
Hi Yizhou, you cannot do now because in Array the PA is Rotator PA, RoboClip Store Sky PA.
Transfer Rotator Management to Array is not easy but is on to-do list.
I do see this feature in single system Sequence configuration. Here on the upper right corner it will load the RoboClip PA, and seems like it allow you to select between Sky PA vs. Rotator PA. Is this what you are talking about?
Yes, “Rotation °” is just an angle … in the rotator tab the selection of “Rotation Type” determine which kind of angle is. RoboClip usually report a Sky PA if generated from the VirtualFOV in Web Dashboard. If you edited manually depends on your original meaning. Array works now only on terms of Rotator PA.
