What does FINISHED_ERROR mean after running VCurve First Lght Wizard?
This is not mine, I am helping a friend.
Peter
Peter
Here is a video of the last 20 seconds of VCurve 1st Light Wizard.
Peter
Hi Peter,
the image show only the last messages âŚwhat happens is detailed in red some rows before.
Please send an email to support with attached a zip with Voyagerâs log.
Video isnât visible here in forum.
I asked my friend to send me the logs.
To view video, right click on the image and click on âView Videoâ or âCopy Video Locationâ or âSave Video Asâ.
Peter
Hi Peter, now I have only Iphone ⌠at home will try.
Ok ⌠iâve seen the video.
Isnât useful without logs ⌠problem is not visible.
Please send the log ⌠but use the support channels:
Logs sent.
Peter
Try reducing the out of focus stars. like 30 or 35.
Thanks Peter⌠I will check as soon as possible
My friend has been using Voyager very successfully for the past several months. I asked him to send me his profile and sequence files. Iâm sure itâs a settings issue.
This is VCurve 1st Light Wizard, not LocalField where it focuses only on one star so changing number of out of focus stars does not seem to apply. Also, he uses Robostar which is also single star focus.
Peter
Where it talks about HFD⌠if itâs failing for a reason itâs usually that youâre moving too far out in my experience. Basically it moves to the middle number then makes data points out to the third value. In my experience, that third value is too small or too big. This applies to Robofire/local field.
Can you give me a screenshot about the HFD settings you mentioned?
FYI: My friendâs equipment:
ES102ED f/7
ASI1600MM-Pro
ZWO filter wheel
Celestron AVX
ZWO EAF auto focuser
Is this where you change the HFD?
Peter
Why your friend choose IN for Focuser direction in Common Parameters ??
Usually this is for the newton with camera against gravity in out !
He have changed the parameters ?
Thatâs my settings. If I set it to OUT, the backlash compensation didnât look correct. I believe if the drawtube racks out, backlash compensation should be invoked (in my case, it is set to âINâ). When drawtube racks in, backlash compensation should not be invoked (in my case, it is set to âINâ). It works perfectly for my setup. When drawtube racks out, the gravity is pulling down the drawtube which affects backlash so backlash compensation is invoked when that happens.
I donât know what settings my friend uses. I asked him for his profile and sequence files. I think he is working now so I wonât get an answer for a few hours.
Peter
Focus and operation need to be done at gravity favour ⌠so out usually is the right way.
In usually is used when you have a newton system and camera on top and gravity push the drawtube inside or whan your SCT telescope need to stop the mirror with the original focuser (not with drawtube).
Yea, so my point was the HFD parameters section. Youâll see three boxes with numbers Near Focus, Start Focus, and Focus limit. I reduced my near focus to â5â (since thatâs close to the 3 I expect it to be) and I kept the start focus at 20. But, when I ran the first light wizard I found that I couldnât achieve outside of 40 HFR due to my focus limits. I reduced it to 30 and that gave me a failure for not enough points; but 35 was the right number to get me a good V-curve.
Given the limited focus available on a newtonian focuser; youâll need to adjust that in my opinion.
Chris
Hey Chris,
One thing about the near focus HFD (and I could totally understand this wrong so feel free to correct me): I think you DONâT want your near focus to be close to your final focus.
From what I observed, it relies on âstart focusâ and ânear focusâ to map two datapoint on the slope, and extrapolate to predict the focuser position to reach focus; If your near focus point is too close to final focus, I think you lose the accuracy in the mapping, as you are not sampling on the most linear part of your V-curve.
Let me know if that makes sense or I am wrong.
Yizhou
OK, Iâll set mine to âOUTâ and see if thereâs improvement. In this case and if the scope points to Zenith and the camera racks out to certain position of the drawtube, you donât think backlash compensation should be invoked? Backlash compensation should be invoked if the drawtube racks in (âOUTâ setting)?
Peter
Youâre probably right; I just found my number works for me and my nite crawler (very precise). The big thing is the default numbers might not work; give it a change if your first light wizard isnât successfully completing
Thanks for the input, Iâll definitely check my settings (as the new guy, I probably got lucky!).
Chris
Never mind when I said about backlash compensation. You are correct about the IN/OUT in Common Parameters and I just changed it for my setup. Iâm still waiting for my friendâs Profile and Sequence files.
Peter
