Hi Leo, at the moment i use the focus whith actual filter ticked on my sequences, but that seems to focus with the old filter when i change the filter… is it possible to have a new flag with a focus with the new filter (if a focus is called after filter change). Thanks for your hard work…
if you use focus with actual filter Voyager use the actual filter and do focus when focus, if after this a change of filter is need the filter will be changed. So I suggest to use group by mode for sequence and for focus, this do focus at each flter change.
