I use a Losmandy G11 gemini 1 level 4. When I connect the gemini.net ascom driver alone, everything works fine. But when I connect this driver for the mount and for PHD2, I have problems. It becomes flaky and gives me communication errors frequently. It should work well as a hub… but it doesn’t. I need help ! thanks !
Hi Pierre,
Have you tried to ask support directly to Gemini producer ? Or to check if there is a newest version ?
Yes, it is the latest version. I just posted this problem on the gemini ascom driver forum.
