Hi all,
I have the Moonlite Nitecrawler as the rotator and I’d like to start the sequence with either X deg (as specified in Roboclip) or 180+X deg. What setting shall choose to achieve that? Thanks!
Yizhou
Hi all,
Yizhou
Voyager at begin sequence use the Rotator/Sky PA requested, you can choose to maintain orientation after meridian flip. You cannot use x or x+180 at begin also for question of guide star.
Thanks. What exactly does “maintain orientation after meridian flip” mean? Say if I am at 90deg skyPA before meridian, and if this option is checked, after flip will it rotate the rotator to maintain 90deg?
Before a difference in what happens to image after meridian using Voyager:
If you use a Rotator PA when a meridian flip happens the image will be rotate by 180° because Sky solving is not used and rotator PA after meridian is the same (its a mechanical rotation).
If you use a Sky PA when a meridian flip happens the image during the solving will be rotate automatically of 180° to mantain the same PA and you will have the same orientation.
If you use “maintain orientation after meridian flip”:
