Hi there,
I already own MaximDL, which is one of two available programs that work with Voyager.
Pls. be patient with me…
MaximDL or TSX are required for Voyager to run, correct?
Is the future “Voyager advanced” feature set going to be included as part of the base license? i.e. should I purchase now, or wait a month?
I would like to purchase a 2 or 3 node array +base license. Does this require I also purchase a “Maestro” license for MaximDL, or does my standard license work?
The Viking product and I/o cards…will this automatically turn off and on ports in my Pegasus Astro ASCOM controlled USB box? Does it allow me to turn equipment off and on? If so, can someone provide a link to hardware it works with?
Not necessary. You can control camera & mount via native ASCOM driver if your camera/mount is supported. You can also use the free Stellarium as the Planetium program. You can use the free plate-solving program such as ASTAP as your solver. Bottomline, you can get a fully functional system with Voyager, without MDL or TSX.
Short answer is No. You can do almost anything you need with ASCOM drivers and Voyager alone. I went that route several years ago and had used MaXIM since version 2 in the early 2000s.
With Viking and an I/O device like the KMTronic referenced on the main website. I would be able to turn off and on my cameras, focusers, rotator, cooling fans etc. as I please, correct? Then, I could use dragstrip to tell Viking to turn on specific devices (i.e, a certain telescope rig), while leaving others turned off? It looks like there are enough ports on that KMTronic to control an array!
