"Maximum Error" in Guiding and Dither Settings
Hey Team!
Another night with V and next questions comes. Does anyone can tell me what the “Maxium Error” exactly means in the Guiding and Dither settings?
From Guiding setting:
" * Maximum Error: The maximum allowable guiding error, in pixels. If the guiding error exceeds this number, a guiding error is assumed"
Does it relate to the total RMS error from PHD2? Or rather the error value to check after starting/resuming guiding at all?
And the one from Dither setting:
" * Maximum Error: The maximum amount, in pixels, to obtain after issuing a dither command before checking if guiding has settled. A value greater than this restart the Settle Time."
I don’t get the part of “obtaining”.
Voyager do internally error calculation and not use PHD2 RMS, also because you can use other guiding system.
More info about here your request here:
https://wiki.starkeeper.it/index.php/Guiding_Setup#Guiding_Setting
https://wiki.starkeeper.it/index.php/Guiding_Setup#Dither_Setting
All are during settle of guiding (normal and after dithering) so are current value and not RMS
