Finally after months of work I have fully automated my home observatory. Now the only things between high quality data are the weather and windows updates
I am super happy to achieve this milestone! I just have to create the target and keep track of the progress.
The image is composed of 50hrs of data captured over several nights, with a TOA150 and a Paramount MX+ from my home in northern Mexico.
If windows updates in Windows 10 are giving you reboots at unwelcome times, you can change the âActive hoursâ when windows does not do automatic restarts, I have my imaging machines set with active hours of approximately 6PM to 9AM so they do not reboot during a run.
Thanks for the tip. The main problem with my observatory PC is that not always get back online after the updates. It is a very old system 2GB atom laptop and usually I have to manually reboot several times after a major windows update. Very annoying that you cannot disable once and for all the autoupdates.
Blueâs solution is what I do also as Iâd like to keep my computer updated (I donât have one in the observatory but connect through Alpaca and using an Icron LAN extender). I also have an IP switch so that I can reboot anything that is unresponsive.
